Motherboard usb issue?
Go to solution Solved by LLOYD-AF,
Removing the cmos battery worked, was able to install windows with no issues.
Hey people,
So i just got a new motherboard and everything was going fine, went into options to check some settings and change the boot order, pc reboots as i'm ready to install windows (usb) but now it wont accept keyboard or mouse commands, its stuck on the (insert bootable device and press any key)
I have no idea what my next move is?
Thank you.
Azure Fists - "Grown men playing with each other since 2009"
CPU : Intel® Core™ i5-4590T, OS : Windows 10 64bit + Custom Alienware Console Interface, GPU : NVIDIA® GeForce® GTX 860M 2GB GDDR5, RAM : 8GB Dual Channel DDR3L 1600MHz, SSD : Kingston V300 240GB, WIFI : Intel® Dual Band Wireless-AC 7265 2x2 + Bluetooth 4.0, CASE : Alienware Alpha, PSU : External Power Brick, MOBO : Custom Dell Motherboard.
CPU : i5 6600, Mobo : Asus Z97i-Plus, RAM : 16GB DDR4 3000mhz Corsair Vengeance LED, GPU : Gigabyte G1 GTX 1080, Case : Silverstone RVZ02, Storage : SanDisk 1TB M.2, PSU : Silverstone Strider SST-SX700-LG, Display(s) : AOC Q2963PM 29" IPS Ultra Wide 21:9, Fans : Noctua NH-L9i with Be Quiet Pure Wings 2, Keyboard : Razer Blackwidow Stealth 2015, Mouse : Razer Naga 2015, Sound : LG Wireless Soundbar /Razer Kraken Pro, OS : Windows 10
https://linustechtips.com/topic/668806-motherboard-usb-issue/
razer something 2016 chroma, it was working in the bios settings menu, strange that it wont work now.
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627679
reboot and press del key
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627680
Ive tried that, like i said its not accepting any keyboard commands.
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627686
Try a different USb port then, if it still won't work on ANY USB ports, find another keyboard just to be able to enter BIOS and check the USB settings.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627690
tried this too :(
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627693
I have never tried this but would removing the cmos battery hard reset the mobo?
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627708
Yes, you can reset the CMOS by removing the battery, make sure the PC is off when you do this of course :)
All it will do is reset to motherboard defaults.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627750
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8627789
Cool, glad it wasn;t a big problem :)
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/668806-motherboard-usb-issue/#findComment-8635106
