Hi all,
So I will give you all a background on the project. I am part of an FSAE team called Oxford Brookes Racing (shameless plug to our website - https://obr.brookes.ac.uk/). I am part of the controls team and last year we developed wireless telemetry using an Arduino and an XBee. This year, after it being a very unreliable connection we are looking at using a WiFi network to send all our data. If we have a fairly standard laptop the receiving end, what kind or AP would i need to be looking at to get about 1-2Km of range? Thanks for all the help!
https://linustechtips.com/topic/668649-long-distance-wifi/
No normal AP would be able to do it, you would need something like this:
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/668649-long-distance-wifi/#findComment-8625737
I think making use of some form of cellular connection would be your best bet.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
https://linustechtips.com/topic/668649-long-distance-wifi/#findComment-8625887
13 hours ago, NRAWhite said:
Just to clarify, we will have the AP or similar on the car itself and use a laptop to connect to it. We will be at a racetrack, so basically and airfield with very little other than distance between the laptop and the car. I hope this helps.
Unfortunately that's not practical to do with a single AP - you'd need a mesh of AP's across the track to provide wireless coverage.
https://linustechtips.com/topic/668649-long-distance-wifi/#findComment-8649095
