16 minutes ago, Juanse said:
Yes, but you'll be putting the capture card on a separate system, which will do the load
Oh I was thinking of using a PCI-E capture card. I have an Elgato Game Capture HD. Could I use something like that? I originally bought it for my PS3 but I was wondering if it would reduce any load off my CPU so I can get better performance out of the game.
https://linustechtips.com/topic/668555-capture-card/#findComment-8624867
