Okay so built my computer couple of months ago and i have only ever used CAT 5 network cables, recently tried using a CAT 6 network cable and my computer doesn't recognise that there is a network cable plugged into it. I've tried uninstalling drivers and following any troubleshooter i found while google searching and nothing fixed it, plugged CAT 5 cable back in and worked instantly. I have an ASRock H1110M-HDS Motherboard. anyone got any idea why it isn't working. I have 4 different network cables to try from and none have worked and all work in another computer.
https://linustechtips.com/topic/668531-ethernet-help/
with cat 5 and cat 6 the only difference is the sheilding around the wires, either the cable is bad, or it could be a crossover cable.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/668531-ethernet-help/#findComment-8624545
But the ports on the router work for the other computer and all cables have been working on that computer. but on mine only CAT 5 cables work. and i knew about the sheilding difference thats why i didn't know what else to try. the fact that one type of cable works but another doesn't. Say i wanted to change motherboards then is there an mATX motherboard that either of you all know of that works on a CAT6 cable (theoretically they all should but to be safe.)
https://linustechtips.com/topic/668531-ethernet-help/#findComment-8627620
