Does it fit in?
Go to solution Solved by TheRandomness,
mATX is a standard. Any mATX board should fit in that case.
Hi LTT commuity,
during a office PC upgrade I encountered a Problem with the size of mainboards:
Old Mainboard: https://www.amazon.de/Asus-P8H67-M-Pro-Rev-3-0-Mainboard/dp/B004O9WT16
The product information says, the dimensions are 40 x 25 x 6cm But the maninboard is square! Are those wrong??
The following Problem: Because I can't be sure whether the dimensions are right, I dont know if the new micro ATX board I want to put in fits.
New motherboard: https://www.amazon.de/Asus-H110M-C-Mainboard-Sockel-Speicher/dp/B015Y0QYP0/ref=sr_1_1?ie=UTF8&qid=1474990036&sr=8-1&keywords=h110m-c
...with the dimensions 35 x 30 x 6 cm
Current case is the picture attaced to this post.
I hope it will work (or there is an alternative mainboard), because logically every micro ATX board should fit in a micro ATX case...or am I wrong?
Hope you understand my problem,
JP
https://linustechtips.com/topic/668021-does-it-fit-in/
Quote
uATX Form Factor
9.6 inch x 9.6 inch ( 24.5 cm x 24.5 cm )
From the ASUS specification page of the P8H67-M PRO. Looks like whoever listed it on Amazon messed up the sizes...
daily driver
Intel Core i7-950 | ASUS SABERTOOTH X58 | 6x2GB Corsair XMS3 PC3-12800 | ASUS GTX970 STRIX | SB X-Fi Titanium
Samsung 840 EVO + WD Caviar Black | Fractal Define R3 | Phanteks/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (13-inch Mid 2010)
Intel Core 2 Duo P8600 | Apple Mac-F222BEC8 | 2x4GB Samsung PC3-8500 | GeForce 320M
SanDisk SDSSDP | Apple A1278 Aluminium Unibody | macOS Sierra
Microsoft Lumia 950
Qualcomm Snapdragon 808 | 3GB RAM | Adreno 418 | Windows 10 Mobile
daily driver 2
Intel Core i5-750 | ASUS P7P55-M | 4x1GB Elpida PC3-8500 | Sapphire Radeon HD5870 | SB X-Fi Xtreme Music
Crucial M4 + WD AV-GP Green | Fractal Define R3 | Scythe/Gelid/Noctua/NoiseBlocker cooling | Windows 10 Pro
MacBook Pro (15-inch, Mid 2012)
Intel Core i7-3615QM | Apple Mac-4B7AC7E434945597E | 2x4GB Samsung PC3-12800 | GeForce GT650M
WD Blue | Apple A1286 Aluminium Unibody | macOS Sierra
server
AMD Athlon 64 LE-1620 | Jetway JNC62K | 2GB Corsair Value Select PC2-6400 | GeForce 8200 IGP
WD Caviar SE16 + AV-GP Green + 2x Red | Chenbro ES34069 | Scythe/Nexus/Noctua cooling | Windows Home Server
coming soon: Eve V
Intel Core i7-7Y75 | Skybay U3E1 | 2x8GB Samsung PC3LP-14900 | Intel HD 615
Intel 600P | Eve V Aluminium Unibody | Windows 10 Pro
https://linustechtips.com/topic/668021-does-it-fit-in/#findComment-8619049
okay. thanks for looking that up...now I looked up the other dimensions for the other board too. Those were also wrong on amazon.....
https://linustechtips.com/topic/668021-does-it-fit-in/#findComment-8619209
