Could someone help me?
Go to solution Solved by asapansh,
PCPartPicker part list: http://pcpartpicker.com/list/s7YmCy
Price breakdown by merchant: http://pcpartpicker.com/list/s7YmCy/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L9i 33.8 CFM CPU Cooler  ($38.88 @ OutletPC)
Motherboard: ASRock Z170M-ITX/ac Mini ITX LGA1151 Motherboard  ($123.99 @ Amazon)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2400 Memory  ($60.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($62.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.71 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Mini ITX OC Video Card  ($397.99 @ Amazon)
Case: Silverstone SG05W-LITE Mini ITX Desktop Case  ($44.99 @ Directron)
Power Supply: Silverstone 450W 80+ Bronze Certified SFX Power Supply  ($69.99 @ SuperBiiz)
Monitor: Acer G257HU smidpx 25.0" 60Hz Monitor  ($243.99 @ Newegg)
Total: $1317.51
Generated by PCPartPicker 2016-09-25 19:22 EDT-0400
I need help picking parts for my computer I only have 1300 dolars to spend on it. It also has to have a monitior and a motherboard with wifi or a wifi card.
Please @Dormant God or quote me if you want me to see your message/reply
        Custom PC Specs
Custom PC Build: (CPU) i7-6700k (MotherBoard) GIGABYTE G1.Sniper Z170 SLI ATX (RAM) 16 GB Dual Channel DDR4/3000MHz (GPU) MSI GTX 1080 (Case) Crystal 570X RGB (Storage) 1 TB HDD from Seagate
https://linustechtips.com/topic/666732-could-someone-help-me/
Just now, Dionyz said:
What do you do on the computer?
Gaming PC and some editing.
        Custom PC Specs
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8605903
        Custom PC Specs
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8605906
Just now, W-L said:
-Moved to New Builds and Planning-
I didnt know if there was a place for that or not
        Custom PC Specs
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8605919
NVM
        Custom PC Specs
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8605990
Total: $1317.51
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8606021
my latest post includes a 1400p monitor and the system is mini ITX. are you fine i=with spending 18 dollars more for the new system?
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8606024
Yes
        Custom PC Specs
https://linustechtips.com/topic/666732-could-someone-help-me/#findComment-8606482
