So a pin on my mobo for the USB 3.0 header broke, and i just recently bought a card reader and the card reader has a USB 3.0 connector. I mainly just want the card reader for the memory cards its allows but now since my USB 3.0 header isn't working, i'm not sure if my card reader  will still work.
Or in another case, will i just not be able to do front panel I/O for USB 3.0 and the other things such as USB 2.0 will still work.
http://www.ebay.com/itm/5-25-All-in-One-Media-Dashboard-Multi-Function-Front-Panel-Card-Reader-USB-SATA-/361655311658?hash=item5434561d2a:g:Y2AAAOSwbsBXkcS7
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/666692-525-card-reader-help/
yes everything else will work just fine.
if you really need the usb 3.0 ports  you could get this cable
the ports will work at usb 2.0 speeds but at least they will be functional
Core i7 7700k Kabylake stock + Kraken x52 | ASUS Z170-A | 8GB DDR4 2133MHz HyperX | ASUS GeForce GTX 1060 STRIX 6GB | 250GB SSD Samsung 850 EVO + 2TB HDD WD RE4 | Seasonic X-Series 650w | Corsair 460x RGB  | Win 10 Pro 64 bit | Corsair M65 PRO RGB Mouse | Corsair K70 RGB RapidFire
https://linustechtips.com/topic/666692-525-card-reader-help/#findComment-8605533
the 5.25 card reader will use 2 USB 2.0 headers, so there would be no space left since my mobo maxes out at 2 usb 2.0 headers. eitherway thanks for the reccomendation :)
https://linustechtips.com/topic/666692-525-card-reader-help/#findComment-8605536
