not bad, you did fine. we'll need a budget and country to work with btw.
https://linustechtips.com/topic/666495-first-ever-build/#findComment-8603216
5 minutes ago, rwaalph said:
Im making my new pc can you check or recommend thanks ;)
I would recommend a cryorig H7 cooler instead of a Hyper 212 evo if its reasonably affordable where you live. Other than that the build looks good imo (without getting really nitpicky about random shit)
https://linustechtips.com/topic/666495-first-ever-build/#findComment-8603223
thanks i looked into this and this suggestion was very helpful, i'm gonna check if my local retailers have it or i will just purchase on newegg
https://linustechtips.com/topic/666495-first-ever-build/#findComment-8603276
