Help! My Pc Build
Go to solution Solved by PRTI,
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£210.00 @ Amazon UK)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  (£39.99 @ Ebuyer)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  (£85.99 @ Amazon UK)
Memory: Kingston FURY 8GB (1 x 8GB) DDR4-2133 Memory  (£34.99 @ Novatech)
Storage: Kingston SSDNow UV400 240GB 2.5" Solid State Drive  (£54.99 @ Amazon UK)
Video Card: Palit GeForce GTX 1070 8GB Dual Video Card  (£368.28 @ Aria PC)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  (£54.51 @ CCL Computers)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£63.98 @ YoYoTech)
Total: £912.73
Generated by PCPartPicker 2016-09-25 12:44 BST+0100
If you could spend more then i did not want to downgrade you to a GTX 1060 (Ik that a i5 bottlenecks a GTX 1070 at 1080p and 1440p but its better than a i7 + GTX 1060 combo)
If you cannot get a GTX 1060
Hello. I'm making a gaming PC build for the first time but could use some help. I would prefer it to have an nvidia graphics card but it is not absolutely necessary. Here is a list of things you might need to know.
BUDGET: 700-850 Pounds
AIM: Will be used mainly for gaming but will need to do work on it as well
MONITORS: I only plan on running 1 144hz monitor
PERIPHERALS: I plan on buying Windows 10 and monitor separate from the build and if anyone could recommend a budget keyboard and mouse for gaming that would be great.
CASE: I would like a mid case, would prefer a window but not necessary
WHY ARE YOU UPGRADING: I am not upgrading as this is my first build.
Thanks for reading, if you can please help!
https://linustechtips.com/topic/666460-help-my-pc-build/
Total: £912.73
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8602952
2 minutes ago, Zyndo said:
That isn't really true. it happens in only a select few games. The very large majority of the time in most games the 6600k will get you to 144hz just fine.
Nah, 6600K bottlenecks a 1070/1080 at 1080p
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603004
why are people still on this i5 is god CPU BS.
10% difference in GTA V when both are OCed and most of the time the i5 just catches up to the i7 when it is OCed to 4.5GHz, who says that you can get that OC? Also that is with maxwell Titan X, not Pascal, so this is basically a 1070. This graph is by digitalfoundry.
You might look at it and think oh that is nothing, well now think about the i7 giving you a more stable FPS, now think about that the i5 when running at 4.5GHz bearly gives the same FPS as a stock 6700k and what if you cannot get your i5 to that, now think about if your CPU goes up to 80-90% or over, then you might get some stuttering. Lastly think about the future.
and then you have this video that shows that at 1080p locked 60 FPS the 6600k at 4.5GHZ has a really hard time with a 1060. We even see 99% in witcher 3 and if you think it will get better in the furture then you are a fool, it will only get worse, when "next gen" games start hitting us in 2-3 years, then that i5 is fucked harder than it already is. Games are getting more and more CPU demanding.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603006
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603008
The text is a little fucked up for me, its all black and the letters are gray
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603020
Just now, keNNySOC said:
The next is a little fucked up for me, its all black and the letters are gray
2sec
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603022
did it fix it?
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603024
Just now, Dackzy said:
did it fix it?
its fixed.
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603026
Congratulations. You all picked a handful of games to prove your point. I'm glad we are in agreement (people link these DF videos literally every single time)
I've no desire to have this conversation yet again with a fresh batch of people. If you wanna go cherry pick your CPU bound games in CPU bound situations with inferior RAM and poor logic in order to prove the 6600k is rubbish.... then i shall not interrupt your little club.
I'm not saying the 6600k is the best or perfect or anything along those lines. I'm saying in MOST games (not ALL) this isn't a problem.
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603027
4 minutes ago, keNNySOC said:
Yup now its all good
And here we are, another day, another need to explain why the i5 6600k is not for a GTX 1070/1080
and the target audience is too damn think-skinned to listen... WHAT A GREAT DAY! #sarcasm
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8603044
Total: £912.73
For storage won't I need a hardrive as well because I'm not sure 250gb will fit all my storage in. Also what is the best budget 16gb ram that works with this build and what gtx 1060 should i get? I would also like to know how upgrade able the build is in the future if u could say thanks.
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8605177
Total: £912.73
Could you clarify for me
-What Hardrive should I use with ssd (would like it to be 1tb)
-What 16gb ram should I put in the build
-how upgrade able is the build
-if I got the gtx 1070 and its bottlenecked will it still perform greater than the gtx 1060
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8605668
-WD Blue is a decent one
-I recommend a set of G.skill Ripjaws 5
-Pretty good upgrade path, you can get a Kaby Lake CPU latter on
-If you OC it a little bit, it will still perform better than a GTX 1060 even if its bottlenecked
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8605677
So do you recommend me getting a gtx 1070 and upgrading to Kaby lake in the future. what psu would I upgrade to to make it not bottleneck. Btw thanks so much your very helpful
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8605699
Look, Its not like that
a PSU cannot bottleneck, a CPU bottlenecks the GPU, and a i5 6600k will bottleneck the GTX 1070, but even if there is a bottleneck, it will perform better than a GTX 1060
The PSU i linked will work just fine
And yes i recommended maybe later upgrading to like a i7 7700k
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8605709
Ok thanks so much
https://linustechtips.com/topic/666460-help-my-pc-build/#findComment-8607274
