Current case: Thermaltake Level 10 GT (about 5 years old)
Looking for the best airflow possible that can house Noctua D15
Anyone recommend the new Corsair 740 air?  D15 compatible?
----Edit---
Some drawbacks of the 740:
No room for dvd drive
No bottle dust filter
https://linustechtips.com/topic/666427-best-airflow-cases/
----Edit---
Check out Phanteks 400.
They come with a windowed side, or closed side.
It also comes with 3 different colours.
  • Black with Green LED.
  • Grey with Red LED.
  • White with Blue LED.
Another option I would suggest is the NZXT Noctis 450.
It comes with 4 pre-installed fans (1 exhaust and 3 front fans), it also has room for 2 more ontop and can fit a nice aio kraken there too.
It comes in 2 different colours:
  • Black with Red LED
Edited by Inspirational
Added NZXT
This is the current build I am working on:
>>>> The $2500 ($1900 US) Desktop <<<<
>>> Old Build <<<
LAST UPDATED: 30-September-16 / 05:38PM (Sydney Time)
https://linustechtips.com/topic/666427-best-airflow-cases/#findComment-8613025
If you don't care about aesthetics too much then get something like a HAF series case. My HAF 912 for my old AMD system was insanely good for that, which is kind of the point of the H.A.F acronym. Seriously good for entry level, if you can get something like a 932 though that would be better because that will swap the interior from that old school metal color to a black painted interior.
If you want something that looks good then you would probably be better off with something more like a Corsair obsidian case or a 500R or something.
https://linustechtips.com/topic/666427-best-airflow-cases/#findComment-8618281
