AM3+ Silent Cpu fan
Go to solution Solved by FireFlame9222,
slap a noctua fan on it
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
https://linustechtips.com/topic/666357-am3-silent-cpu-fan/#findComment-8601932
1 hour ago, No said:
so i can use the same cooler just with a noctua fan!?!?
you should be able to, it should come with a thing you screw onto the fan (the cpu cooler if its not stock)  that lets it clip on the heat sink, if not see if you can take that off your current cpu fan, or order some with the fan
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
https://linustechtips.com/topic/666357-am3-silent-cpu-fan/#findComment-8601984
yeah it lets me clip on the fan thanks!
https://linustechtips.com/topic/666357-am3-silent-cpu-fan/#findComment-8601993
