I bought a sapphire rx 460 and then found out that i had a monitor which only supports vga.
So i bought an adapter that converts dp to vga.
It works fine but wen i start my pc up it doesnt show the motherbord screen and the windows booting.
It starts to work wen i have to login in wndows 10.
Is the converter the monitor or the gpu the issue?
https://linustechtips.com/topic/665997-rx-460-issue/
It's most likely the converter.
And please.. Get a new monitor.
https://linustechtips.com/topic/665997-rx-460-issue/#findComment-8598326
Be happy the coverter works at all, you're going from a digital to analog video signal
and for the future Plugable makes USB to video outputs, not sure on it's latency though
http://plugable.com/products/usb-vga-165/
Does your card not have DVI-i or whatever, it's the one with 4 extra pins
Also best in class monitor is probably this one at $120, 1080p 75hz free-sync, only downside is TN, but modern TN is actually pretty alright, not worth it at it's normal price of $150 though
https://pcpartpicker.com/product/hqmxFT/aoc-monitor-g2260vwq6
https://linustechtips.com/topic/665997-rx-460-issue/#findComment-8598417
