Need serious help! So confused.
Right where to start.
Currently my ISP is VirginMedia (Fastest UK Provider) Using there router they supplied as my main router (For now will become just a modem when i finally buy some kit and build a pfsense router which will make all this shit redundant and then i will turn the spare netgear router in to a independent firewall but that's for another day)
that runs to a switch (which isn't fully configured yet but that for another day again)
I got a old netgear DG834G for free this is also plugged in to my switch and has a static IP assigned so i can configure it whilst still connected to the ISP router for internet access and plan is to yous that as a VPN so i can access all my connected devices from my work.
by default it supports VPN but i dont have a clue how to configure it so i can use it as a vpn point to access all the stuff plugged in to my switch? is this possible?
the netgear apparently cans support install of OpenWRT can you set it up using that if not the default system?
maybe this image(yes it paint i wasn't gonna do a Photoshop masterpiece for this xD) will help you understand better as i know i got lost just typing this ha.
so ye which way do i have to set it up to stand a chance of having this work? im guess the second way? and still how do i configure this in the settings??
Case:- 4U Rack Mount Case | Cooler:- Antec Kuhler H600 | CPU:- Intel i5 4690K @ 4.50GHz GPU:- Zotac GeForce GTX 970 4GB AMP! Omega Core Edition @ 1449MHz | Motherboard:- MSI Z97S SLI Krait | PSU:- XFX XTR 650W Gold | RAM:- HyperX DDR3 1866MHz 4GB White (x2) Black (x2) | Storage:- Kingston V300 120GB | Storage 2:- Seagate FireCuda 1TB | Build Log |
https://linustechtips.com/topic/665707-need-serious-help-so-confused/
10 minutes ago, kris2340k said:
ive never changed ot setup a VPN but in my router I know there is a box saying VPN in the netgear routers settings page?
ye im aware of that part lol
i need help setting it up so it will work way i want lol
1 minute ago, kris2340k said:
then we shall wait for someone else together as im curious too
indeed lol im trying redit to just due to reddit user base is bigger but ill post on here if i get answer on there
