SQL Help - I'm in over my head
Here is my query as it is:
DECLARE @NewLineChar AS CHAR(2) = CHAR(13) + CHAR(10)
SELECT Response_Master_Incident.Master_Incident_Number
  ,Response_Master_Incident.Problem
  ,CaseNumber.CaseNumber
  ,Response_Master_Incident.Time_CallEnteredQueue
  ,Response_Master_Incident.Time_CallClosed
  ,Response_Master_Incident.Jurisdiction
  ,Response_Master_Incident.Response_Area
  ,Response_Master_Incident.Priority_Description
  ,CONCAT (Response_Master_Incident.Address, ' ', Response_Master_Incident.Apartment, @NewLineChar, Response_Master_Incident.City, ', ', Response_Master_Incident.[State], '  ', Response_Master_Incident.Postal_Code) AS Full_Address
  ,Response_Master_Incident.Call_Disposition
  ,Activity_Log.Radio_Code
  ,Activity_Log.Activity
  ,Response_Master_Incident.Response_Date
  ,Activity_Log.Date_Time
  ,JurisdictionName
  ,CASE WHEN Activity_Log.Activity = 'Available' THEN 0
   WHEN Activity_Log.Activity = 'Terminated' THEN 0
   ELSE DATEDIFF(SECOND, (Activity_Log.Date_Time), (LEAD(Activity_Log.Date_Time, 1, 0) OVER (ORDER BY Response_Master_Incident.ID, Radio_Code, Activity_Log.ID))) END AS Seconds_In_Status
FROM
  LEFT JOIN Activity_Log
    ON Response_Master_Incident.ID = Activity_Log.Master_Incident_ID
  LEFT JOIN Status
    ON Activity_Log.Activity = Status.Description
  LEFT JOIN CaseNumber
   ON Response_Master_Incident.ID = CaseNumber.MasterIncidentID
WHERE
  (Activity_Log.Radio_Name LIKE '[0-9][0-9][0-9][0-9]LM')
  AND Activity_Log.Radio_Code IS NOT NULL
  AND Response_Master_Incident.Response_Date BETWEEN '2016-09-01' and '2016-09-30'
  AND ((JurisdictionName = 'Somename') OR (JurisdictionName IS NULL))
Radio_Code,
Activity_Log.ID
Here are the problems, and I have to use SQL to structure it.
Some of the fields have to be concatenated in some fashion when the row values match - when fields "Master_Incident_Number", "Radio_Code", "Activity", and "JurisdictionName" all match, then CaseNumber needs to be concatenated with @NewLineChar as a separator and Seconds_In_Status (a calculated field I may add) needs to be added together, all in one row. The rest of the fields all should have the same data and can be ignored and merged into one row.
"There is probably a special circle of Hell reserved for people who force software into a role it was never designed for."
- Radium_Angel
https://linustechtips.com/topic/665472-sql-help-im-in-over-my-head/
On 9/24/2016 at 1:42 AM, Nuluvius said:
Good for you. What are you expecting us to do about it?
Helpful, thanks...
- Radium_Angel
On 9/24/2016 at 2:43 PM, Isvan said:
What is happening?
What have you tried to do?
Cant just give use a script and say make it work.
Thank you, it turns out I wasn't paying close enough attention to the structure of the tables, and it was causing some duplicate data.
- Radium_Angel
