I will be upgrading my set up soon and will be getting a 144hz monitor i plan on buying a 1070 would my I7 3770 non k cpu bottleneck the 1070 as i will want 144fps to match my monitor? My cpu is at stock speeds at the moment but i plan on overclocking once i have a all in one water cooler.
Thanks
https://linustechtips.com/topic/665231-need-advice-on-system-upgrade/
Thanks
It depends on the games you're running and at what settings. However, the GTX 1070 won't get you 144Hz on maximum detail for the more recent AAA games as a heads up.
1 minute ago, iamawesome said:
Probably not
Brothers got a 3770 non k with a 1070 and hes doing just fine.
