hi guys,
I was planning to get a gtx 1060 and i5 6600. I originally did not want to overclock.
Now I'm not sure. So I need your advice.
If I was to change the B150 mobo and i5 6600 cpu for a Z170 and i5 6600k, how much gaming benefit would I notice (not actually get but realistically notice) from the more expensive option including a fairly conservative overclock.
Please note, no matter what I choose it will be air cooled only (currently going for Cooler Master Hyper TX3 EVO). Also, I do not want an i7 cpu, that will wait until next year when I'm planning a build with kaby lake, a top of the line gpu, plus whatever next gen ssd and memory is available then.
To help answer, the PC will be connected to a 4K smart tv which I will set to 1080p when gaming.
Current build list:
i5 6600
Asus B150 Plus
Crucial BX200 250gb SSD
Palit 1060 Dual 6gb
Corsair Vengeance 16gb (2x8) DDR4 2400 mhz
Corsair CXM 500 watt
Game Max Silent Gaming case
Arctic case fans (1x140mm, 1x120mm)
The cost of the build (not including OS or peripherals) is around €900. I don't mind the extra cost of the Z170 and unlocked cpu as long it is actually worth it, not just  2-3 fps in games and Windows starting up 2 seconds quicker.
Thanks for any help.
Love not hate
https://linustechtips.com/topic/665023-need-your-advice/
1 minute ago, jeremymwilson said:
hi guys,
Current build list:
i5 6600
Asus B150 Plus
Palit 1060 Dual 6gb
You need more than a TX3 Evo, really. Look in to cryorig.
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8588533
2 minutes ago, jeremymwilson said:
ok will do, thanks
The H7 is the minimum I would recommend for an OC. If you can't get that, think about the 212 Evo or X.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8588549
1080p on a 4k tv...?
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8588574
I know it sounds odd but the only place I can put a pc is in the living room where I already have the 4k tv, that's why I started planning a build in the first place. As mentioned, the above build is only temporary anyway, at some point the 4k TV will make much more sense as a monitor.
Love not hate
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8588587
The H7 doesn't seem to be available where I live. I found this though - https://www.amazon.co.uk/Cryorig-H5-Universal-processor-cooler/dp/B00MBTOY2S/ref=sr_1_1?ie=UTF8&qid=1474561973&sr=8-1&keywords=cryorig+h7
but it doesn't list socket 1151, only socket 1150..
Love not hate
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8588595
Socket 1150, 1156, 1155 and 1151 all use the same mounting. The H5 is better than the H7. Are you in the UK? If so, try ebuyer.
Main Gaming Rig:
Secondary PC:
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8588633
6 minutes ago, brob said:
Consider moving to a H110 motherboard and sticking with the locked cpu. Moving to an unlocked cpu on Z170 will not make a noticeable performance difference unless the cpu is overclocked.
what is the benefit of the H110 compared to B150?
Love not hate
https://linustechtips.com/topic/665023-need-your-advice/#findComment-8589558
