Don't buy a motherboard that supports 6th gen CPU and DDR3 - its going to reduce the life of your CPU significantly. That is because DDR3 uses 1.5V and DDR4 uses 1.2V. Skylake is designed to use lower voltage on the RAM.
i7 6800K
Corsair H110i GT
Asus ROG Strix X99 Gaming
Corsair Vengeance LPX (4x4GB) 3200MHz
Samsung 850 EVO 500GB
Seagate Barracuda 3TB
R9 270X
NZXT H440 (Black/Red) 2015 Edition
EVGA SuperNOVA P2 850W
BenQ XL2411Z
https://linustechtips.com/topic/664995-motherboard-help/#findComment-8588197
https://linustechtips.com/topic/664995-motherboard-help/#findComment-8588227
17 minutes ago, Chadders said:
Hello, does anyone know any cheap motherboards that support a 6th gen intel CPU and DDR3 RAM?
Thanks.
why ddr3? ddr4 is much faster and is about the same price.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/664995-motherboard-help/#findComment-8588244
Just now, Chadders said:
I just have had ddr3 in my computer this isn't a fresh build
sry, but you are not going to find any lga 1151 boards that support ddr3, they can only support ddr4
SPECS:
https://linustechtips.com/topic/664995-motherboard-help/#findComment-8588258
https://linustechtips.com/topic/664995-motherboard-help/#findComment-8588302
