Hi,
I have a MSI Z77a-G45 gaming board. It has the above network adapter built in.
It did work but just installed windows 8.1 new update. Now it doesn't, put the MSI disk in to reinstall but states 'your hardware is not supported on this windows configuration'
Any ideas how I can get around this and get my PC back connected to the net?
Thanks guys :-)
Commodore 64 without the SID?? Whatever!!
6581 The power of the C64  :)
https://linustechtips.com/topic/66436-killer-qualcomm-problem/
Try and download the latest drivers of the killergaming website:
http://www.killergaming.com/support/driverdownloadsupport
Don't bother with the MSI website, they don't keep their drivers up to date.
That should fix your problem. I know it fixed a different problem I had with my Qualcomm ethernet.
(\__/)
(")_(") This is Bunny.
https://linustechtips.com/topic/66436-killer-qualcomm-problem/#findComment-907970
Hi,
Thanks guys :-)
What IS  Commodore 64 without the SID?? Whatever!! ...From Google is it the part of the Commodore that controls the sound or? O.o
Also Glad you saw this post :D
PROFILEYEAH
What do people even put in these things?
https://linustechtips.com/topic/66436-killer-qualcomm-problem/#findComment-907992
Thanks for the info, had to use the wifes iMAC to get the files......I feel dirty!!!!! lol
https://linustechtips.com/topic/66436-killer-qualcomm-problem/#findComment-912143
Yep just get the new drivers on a USB stick and BAM your sorted ;-)
I already tried to install the latest drivers (both downloaded from gigabyte and killergaming website), but nothing happened. Anyway, I already downgraded to 8. I'll just wait 2-3 months before upgrading again to 8.1
https://linustechtips.com/topic/66436-killer-qualcomm-problem/#findComment-919710
