Posted September 20, 2016 AIO water cooling recommendations with clear tubes and dyes so you can see the water for both cpu and gpu, Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 20, 2016 Author Just now, EnemySp0tt3d said: what Dyes, sorry i ment color dyes Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/#findComment-8579009 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 20, 2016 (edited) Rajintek makes what you're looking for buddy. RAIJINTEK TRITON GREEN v02, All-In-One Liquid CPU Cooler with New Pump, Water Block, Tank Design, 2*12025 Fans, 240mm Radiator, 2 LED Light, Fan Controller, Solid Mounting Kit, Sturdy Installation http://www.newegg.com/Product/Product.aspx?Item=9SIA66Z29E8183 edit: at least for the cpu. Edited September 20, 2016 by Lost_woz Added info Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/#findComment-8579010 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 20, 2016 I think you'll need custom loops to see the GPU. i5-8600K - Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/#findComment-8579031 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 25, 2016 Author AIO water cooling with clear tubes recommendation please and no RAIJINTEK TRITON, Ive head they leak Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/#findComment-8601180 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 25, 2016 The Swifttech H220 has clear tubes I believe. And it is expandable. http://www.newegg.com/Product/Product.aspx?item=N82E16835108217 Andrew "FirstM8" Wanamaker Missouri University of Science and Technology Freshman Engineering - Computer Engineering Missouri S&T IT Help Desk Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/#findComment-8601203 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 25, 2016 http://www.swiftech.com/h240x2.aspx Link to comment https://linustechtips.com/topic/664106-aio-water-cooling/#findComment-8601205 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 25, 2016 I have H240 X2 work well but beware of the pump noise ... I looking to rma back to my store when stop stocking it and getting refund and going with EK predator. Apart from pump noise everything else is great. Magical Pineapples
