Switch limiting my internet speed?
Go to solution Solved by Lurick,
That's because it only has 10BaseT ports which are 10Meg ports
http://www.mtmnet.com/3C16900.htm
I have the 3com Superstack II Switch 1000 that I have recently installed in my network. My network setup looks like this c05cdb0e0a.png
The problem is that without the switch in the way, I get 60mb down, but with it I only get around 7mb down. This is not only with youtube and stuff, it is also with in-network file transfers through Windows Homegroup. Is the switch just too old or what?
https://linustechtips.com/topic/664094-switch-limiting-my-internet-speed/
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
Just now, Oberon.Smite said:
So I'm guessing I'm limited to 10mb/s with this thing?
Yup
You can pick up a switch capable of doing gigabit for like $30 to $50 for a 5 to 8 port, like this:
https://www.amazon.com/Netgear-GS105NA-Prosafe-5-Port-Gigabit/dp/B0000BVYT3
Prior Build Log/PC:
4 minutes ago, Lurick said:
Yup
Thanks a shit ton man. Looks like the old one is going up for sale to fund a new gigabit switch! In the meantime I'll use the extra ports on the other router.
Not to discourage you, but you probably can't get more that $1 for that thing. Last time I worked with 10base t was for setting up a nostalgia network.
My native language is C++
