I think it would look pretty awesome if they were synced, if not then it will still look cool, but weird.
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/664055-rgb-build/#findComment-8578416
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/664055-rgb-build/#findComment-8578458
2 hours ago, SLAYR said:
The PSU's cables are as ugly as a butt and the RAM appears to be laptop ram. (could be wrong).
Also the PSU would be in a basement (Probably in EVGA's new case) so the RGB wouldn't do much. It would probably be better to put a lighting kit on there but hey ya never know. Thanks for the suggestion
Also I dont need 1250W of power. More like 750-850 probably (Dual 1080's is my plan)
Breaking things 1 day at a time
https://linustechtips.com/topic/664055-rgb-build/#findComment-8579211
