I am currently at a loss, the system will not post.  The GPU CPU and the case fans power on.  The HDD powers on.  Ill start with the system specs:
AMD FX6300
Nvidia GTX 650ti
8GB Crucial Ballistix Sport
MSI 970 Gaming Mobo
Corsair CX430 GPU
I have tested the ram and GPU in another system so I know they are not the problem
I have tried a different PSU(from a working system)
I ordered a new MOBO and CPU still no luck, same issue.
I am completely lost here I have tried virtually every part and still come up with the same issue. Any help is appreciated. thanks.
https://linustechtips.com/topic/663990-pc-will-not-post/
AMD FX6300
Nvidia GTX 650ti
MSI 970 Gaming Mobo
Corsair CX430 GPU
Are the CPU/Mobo pins bent? Everything is plugged in properly? Will it boot BIOS or just not OS?
My System:
Intel Core i5-4690k  / Cooler Master Hyper 212 Evo Asus Z97-AR MSI Nvidia GeForce GTX 970 100me Corsair Vengeance LP 1600Mhz 2x4GB DDR3 Samsung 850 EVO 250GB / Seagate Barracuda 1TB 3.5" 7200RPM HDD / NZXT S340 EVGA SuperNOVA G1 650W / Windows 10 Home 64 / AOC G2460PQU 1080p 144hz / Corsair VOID Wireless RGB Razer Taipan Laser Razer Blackwidow Ultimate 2014
My Laptop (Asus X55C-DS31):
Intel Core i3-2370M @ 2.4Ghz 6GB RAM / OCZ ARC100 240GB SSD /
My Phone:
OnePlus Three Graphite Black / 64GB
My Watch:
Moto 360 1st Generation
https://linustechtips.com/topic/663990-pc-will-not-post/#findComment-8577591
10 hours ago, kris2340k said:
Let us know after youve read and done everything there as until you have
thats pretty much anyone is going to suggest
I have done all of this still nothing.
10 hours ago, Curious Pineapple said:
Tried running it out of the case? Could be something shorting out on the case.
The system is currently pulled out of the case.
Nope, everything looks visually fine.
https://linustechtips.com/topic/663990-pc-will-not-post/#findComment-8580416
On 9/20/2016 at 1:51 PM, BiscuitMassacre said:
14 hours ago, kris2340k said:
I still dont understand what happens when you turn it on, do you see the boot splash screen or not?
The fans come on but the screen remains black. No boot screen, no bios screen. Its like there is no signal going to the monitor but as i said before i know its not the graphics card.
https://linustechtips.com/topic/663990-pc-will-not-post/#findComment-8585858
Bad ram?
Bent cpu pins? (check them all)
Dead cpu, or corrupt bios?
Recently done things with case (DIY) to create metal flakes, causing shorts?
Desktop:
Intel Core i7-6700K 4.5GHz Corsair H100i v2 | Asus Z170-A | Corsair Vengeance LPX 16GB 2x8 3200Mhz | Samsung 960 EVO 1TB + 850 EVO 250GB + Seagate 1TB | GIGABYTE GeForce GTX 1070 G1 Gaming Cooler Master MasterCase Pro 5 | EVGA SuperNOVA G2 650W 80+G | Microsoft Windows 10 Home 64-bit (PcPartPicker)
https://linustechtips.com/topic/663990-pc-will-not-post/#findComment-8586168
AMD FX6300
Nvidia GTX 650ti
MSI 970 Gaming Mobo
Corsair CX430 GPU
Are you plugging the monitor into the Graphics card or the Motherboard?
1474409643.6492558
https://linustechtips.com/topic/663990-pc-will-not-post/#findComment-8586301
