You can plug Fans direct in the PSU.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/663242-more-case-fans/#findComment-8569455
Not entirly sure how much, but think that once you would hook up to much at 1 header you can lose RPM control and just start spining fully or stop. A fan hub might be a better choice if you go for 3 or more fans. One that has his own power delivery should not have issues.
The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane.
Basic PC parts guide
PSU Tier list
https://linustechtips.com/topic/663242-more-case-fans/#findComment-8569619
