Hi, so I am gonna build my first gaming build in about a week and just checking in here to see if there's anything I'm missing or if I should change something.
All the prices will be in Norwegian Kroner (NOK), I've made a .txt for the parts and pasted it below.
---===Computer Components===---
CASE      ; Corsair Carbide SPEC-03 - 695kr - https://www.komplett.no/product/808809
MOBO      ; MSI Z170A Tomahawk - 1699kr - https://www.komplett.no/product/865058
CPU i7    ; Intel Core i7-6700K Skylake - 3490kr - https://www.komplett.no/product/850037
RAM       ; HyperX Fury DDR4 2133MHz 16GB, 8GBx2 - 839kr - https://www.komplett.no/product/882947
GPU       ; MSI GeForce GTX 1060 6GB Gaming X - 3389kr - https://www.komplett.no/product/894857
PSU       ; EVGA BQ 650W Hybrid Modular 80+ - 899kr - https://www.komplett.no/product/895089
HDD       ; Seagate Barracuda 1TB 3.5" 7200RPM - 529kr - https://www.komplett.no/product/653050
TH.PAST   ; Thermal Paste - 119kr - https://www.komplett.no/product/460665
CPULQ     ; Corsair Hydro Series H55 CPU Liquid Cooler - 699kr - https://www.komplett.no/product/769187
OS        ; https://www.kinguin.net/category/22175/windows-10-home-oem-key/ - 221,65kr + 9,24kr Kinguin buyer protection = 230,89kr - REMEMBER USB https://www.microsoft.com/en-us/software-download/windows10
-=Price=-
CPU i7    - 3490kr
MOBO      - 1699kr
RAM       -  839kr
GPU       - 3389kr
PSU       -  899kr
CASE      -  695kr
HDD       -  529kr
TH.PAST   -  119kr
CPULQ     -  699kr
| Different CPU/Cooler Prices
| i5:   11085kr
| i7:   12185kr
| LQi5: 11489kr
| LQi7: 12589kr
i5:   Price with normal CPU Cooler and i5-6600K Skylake CPU
i7:   Price with normal CPU Cooler and i7-6700K Skylake CPU
LQi5: Price with Liquid CPU Cooler and i5-6600K Skylake CPU
LQi7: Price with Liquid CPU Cooler and i7-6700K Skylake CPU
[s]CPUCOOL   ; Cooler Master Hyper TX3i - 295kr - https://www.komplett.no/product/891804[/s]
[s]OP.DVD    ; ASUS DRW-24D5MT - 249kr - https://www.komplett.no/product/896902[/s]
[s]FANS      ; Corsair Air AF120 Quiet, 120mm fan - 199kr - https://www.komplett.no/product/756831[/s]
[s]CPU i5    ; Intel Core i5-6600K Skylake - 2390kr - https://www.komplett.no/product/850035[/s]
[s]CPU i5  - 2390kr[/s]
[s]OP.DVD  -  249kr[/s]
[s]FANS    -  199kr[/s]
[s]CPUCOOL -  295kr[/s]
MOBO = Motherboard
PSU = Power supply
OP.DV = Optical Drive
TH.PAST = Thermal Paste
CPUCOOL = CPU Cooler
CPULQ = CPU Liquid Cooler
https://linustechtips.com/topic/662814-building-my-first-pc/
It's basically fine the way it is, but I'd make a small suggestion.
Get a basic CM Hyper 212 EVO cooler instead of the Corsair Hydro and use the money saved to get at least a 120Gig SSD to use as the OS boot drive (and often used apps/games).
You could also get a cheaper 550 watt (80+) power supply, if necessary to afford the SSD.
A sieve may not hold water, but it will hold another sieve.
i5-6600, 16Gigs, ITX Corsair 250D, R9 390, 120Gig M.2 boot, 500Gig SATA SSD, no HDD
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564431
2 minutes ago, Kantor said:
you get a psu with a better rating but otherwise this looks like a solid build.
That PSU is fine.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564443
Eh, get a Cryorig M9i or BeQuiet! PURE ROCK. The Evo doesn't deserve as much attention as it gets.
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564447
What is the resolution and refresh rate of the monitor you are gaming at?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564448
I'm running a 24" monitor at 1920x1080. 60hz
I'm not gonna use an SSD, I believe it's just overpriced and doesnt give me enough space for what I need.
atm I'm just posting the build here to see if everything is nice, I'm not really planning on replacing anything unless it is required af.
EDIT: And does anyone know if Kinguin is a trustworthy site for an OS?
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564466
Only problem is that a 1060 is a bottleneck for an i7 6700K. A 1070 would be a better match if you can afford it.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564497
If its 60Hz, I feel like the i7 would be a bit of a waste for games. Do you plan on editing videos and streaming?
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564512
Just now, sebasti161 said:
Most likely, yes.
Well, your are going to get some benefits out of it then. Do consider getting a 120GB SSD, you can save up by ditching the thermal paste (You get some with almost every cooler in the market) and maybe looking for a still decent power supply with less wattage (650W is a bit of waste for a 1060, maybe 550W).
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564526
I just don't understand the point of an SSD, space>speed
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564531
You don't need to be limited with a SSD only, get a HDD and a SSD, install the OS in the SSD with some of your favourite games. Put everything else in the hard drive. It's really a pain to deal with a slow mech drives in some games due to loading times (particularly games like battlefield), boot times also improve a lot.
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564552
If you put your OS and programs that you most frequently use on it, your computer will feel much more responsive. The computer would boot faster. Then use the hard drives for mass storage.
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564555
It's just way too expensive, I've alreay gone multiple thousands over what I intended the build to cost
I've been using HDD's for atleast 5 years now, no big deal if the computer doesnt respond for a little bit.
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8564566
If you are concerned about cost, there are several things you can do:
CPU: there's no real advantage (in gaming) to having an i7 over an i5. You could save a lot by getting an i5-6600K
RAM: 16Gigs is nice, but 8Gigs is really all you need.
Motherboard - there are lots of less expensive Z170 motherboards.
Cooler - a basic CM Hyper 212 works almost as well as that AIO unit, but costs a lot less. (a few degrees extra temperature won't hurt anything)
Thermal paste - most coolers come with thermal paste (the Hyper 212 and that AIO one do), so there's no need to buy any extra (unless you screw up the install :) )
With all those cost savings you could easily afford an SSD. And, believe me, once you get an SSD you'll never go back to just using a hard drive. The whole system become noticeably much more responsive
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8570911
I ordered the stuff an hour ago, too late pal :(
Anyways, the reason I'm going with that MOBO is because of it having wireless connection.
https://linustechtips.com/topic/662814-building-my-first-pc/#findComment-8571188
