Hey again, quick bit of help - what am I doing wrong with my bends?
they are usable but a tiny bit squished...
I feel like maybe the silicone insert is too loose?
or is it too much / too little heat?
(this is the spare monsoon tubing so I am practicing! )
Build Log : Red N White Army
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
Palit 980 Ti Super Jetstream
16GB HyperX Savage 1866 RAM
Samsung 850 Evo 500GB SSD
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/
How long are you putting it under the heat? I know that's kind of hard to articulate since there are a lot of factors involved with that but I remember when I first started I would see similar results if it wasn't hot enough or I bent too fast and/or twisted while bending.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8558376
Main Rig:-
Server:-
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8558384
Maybe you are right and it's not hot enough. I didn't twist but definetly felt like I was forcing the bend a little.
Maybe it was under low heat for two minutes or so?
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8558459
how tight does the insert fit into the tubing?  It looks like it might be a bit too small, it should fit almost snug, but not tight.
 also try heating a slightly larger area of tubing
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8558558
I think the insert is OK - this is it.
Watching the video above I think I didn't heat it enough. Will try later when the kids gone to bed!
http://www.watercoolinguk.co.uk/p/WCUK-Bend-Cord-Insert-for-12mm-ID-Acrylic--PETG-Tube-Bending-500mm_58116.html
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8559101
could be.  Do you have a pic of the cord inserted into the tubing?
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8560267
So the monsoon tubing is looser than the EK tubing but on reflection maybe it is too loose on both?
the website says it measures 11.5mm but I measure it at 11mm
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8560704
is that supposed to be 12mm ID tubing?  that is definitely looser than mine was, mine just slid in with very little gap.  I often had to rotate it just to get it out after bending.
you could still try a couple with more heat and that same bending cord, they might come out better.  You may need to get a different cord though, I usually buy 2 different ones that should fit my tubing and usually only one of them fits nicely
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8560767
Think it might be the monsoon tubing, with the EK tubes it's a lot better, still not perfect but still much better -
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8564014
that does look better, but still looks like you may be stretching the outside radius of the bend a little.  Try heating up another 1" of tube when you do the bend so that the bend doesn't have to stretch things out as much
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8564024
Will give that a go next time. With this bend I was more worried that there was only a small distance between the bend and the fitting so I didn't want there to be too much deforming of the tube that went in there in case of leaks
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8564472
yeah I ran into that a few times.  I wrapped a soaking wet rag around the segment that I wanted to go into the fitting to help keep it cool.  Seemed to help quite a bit
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8564484
Thanks for that last tip, actually it helped a lot with a bend which was too tight and sprung a leak.
Because it was tight using that method resulted in a crappy looking bend but it dealt with the leak.
System Specs
NZXT S340
i7 4790k
Z97 MSI Gaming 5
EVGA 750W G2 PSU
Custom Cooling Loop
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8572967
nice, glad it helped! :D
Edited by 0ld_Chicken
added EMOTION
https://linustechtips.com/topic/662187-petg-bending-advice/#findComment-8573097
