4 minutes ago, Riveter1 said:
Hi folks. I have maybe stupid question. Do i can use 4 pin splitter on 3 pin fans. Coz i have 9 be quiet pure wings 2 fans (3 pin) and i want to connect them in one block. And maybe u have some suggestions for this. Thanks
While you can use 4 pin splitters you wouldn't want to power it via a single motherboard header as that would easily overload it. I would suggest to get a fan controller like the NZXT Grid+ if you want to control them as a huge group together or the Grid+ V2 for individual control.
https://linustechtips.com/topic/661403-fan-splitters/#findComment-8550646
I have thoughts before about grid+ but are they fixed that issue whit fan speed stuck at 100% and that u can't change ? Coz i know that before was a lot of issue with that kind of thing. And what about if I put not one splitter but couple for example in one 6 and in other 3? Is that will make more sense? Or is better just stick with your option?
https://linustechtips.com/topic/661403-fan-splitters/#findComment-8550961
That would still be too many fans per header a good rule of thumb is no more than 3-4 fans per header to not overload it depending on the fan. I didn't hear about that issue before so I wouldn't be too sure but they are software controlled via their CAM software.
https://linustechtips.com/topic/661403-fan-splitters/#findComment-8551001
