I've been searching for a 4k monitor, that has at least USB 2.0 for 60 hz, HDR which I think is at least ten color bit? As well as not costing 2000 dollars I was about to give up until I got the email to finish this up..so here goes, I don't post on forums too often so forgive me. This is for the xbox one s.
https://linustechtips.com/topic/661133-no-hdr-for-monitors/
I don't think many exist. You will have to get a TV and that's better for media anyway.
Home PC: i5 6402P | Kingston HyperX 8GBx2 | Gigabyte G1 gaming GTX 1060 | Kingston UV400 240GB | WD blue 1TB Gigabyte H110m-S2 Cooler Master B500 v2
Laptop: Lenovo Yoga 710(Kaby Lake)
Phone: Oneplus 3
Tablet: iPad air 2
https://linustechtips.com/topic/661133-no-hdr-for-monitors/#findComment-8547632
uh...
- why do you need a 4K montior for an xbox?
- does the one s finally run games at 60FPS?
- there is nothing the xbox can do where high dynamic range matters one bit.
https://linustechtips.com/topic/661133-no-hdr-for-monitors/#findComment-8547642
HDR is more of a TV thing. For monitors, adobe RGB and sRGB are the high color things for monitors, but they are really only usefull for media creation. Just find the smallest 4k HDR tv you can find if you really want to take advantage of HDR. But honestly just go for any high-response time 4k monitor
https://linustechtips.com/topic/661133-no-hdr-for-monitors/#findComment-8547682
7 hours ago, SCGazelle said:
HDR is more of a TV thing. For monitors, adobe RGB and sRGB are the high color things for monitors, but they are really usefull for media creation. Just find the smallest 4k HDR tv you can find if you really want to take advantage of HDR. But honestly just go for any high-response time 4k monitor
I have one already but unfortunately it doesn't have hdmi 2.0 so it's not recognized by the xbox one, we'll it is but it doesn't upscale to 4k or stream 4k with out that so I figured I'd grab another one with everything I needed...I guess I'll have to look ino tvs
7 hours ago, manikyath said:
uh...
I'm not sure you know what your talking about but thanks....
https://linustechtips.com/topic/661133-no-hdr-for-monitors/#findComment-8550173
Thanks yo! I was looking into monitors cause I'm used to the responsiveness but I'll research some tvs. thank you!
https://linustechtips.com/topic/661133-no-hdr-for-monitors/#findComment-8550179
