They would all be about the same. I don't think anyone is much better than the other. Get one that comes with anti corrosives and anti microbial already in the mix, and then just get one in the colour/opacity that you wish.
Of course, I'm no expert in the area. But coolant is fairly cheap (compared to the cost of the computer and the loop you put the coolant into). pick something and try it out. if it fails or you don't like it then clean your loop and put something else in. This is what being an enthusiast is all about! =)
https://linustechtips.com/topic/660301-best-premix-coolant/#findComment-8538796
22 minutes ago, Shadowman said:
Which would you is currently the best or very very good premixed coolant?
Mayhems makes some of the best stuff currently if you want a transparent coolant their X1 series would be something to look into, they also have an opaque version with their Pastel line of fluids.
https://linustechtips.com/topic/660301-best-premix-coolant/#findComment-8538802
