Had the update installed on mine without performance problems. I can only think if the old trick might still work of manually deleting the cache partition contents. You'll have to search for instructions but it involves certain keypresses when starting up to access the menu.
  1. Go to recovery and delete cache partition.
  2. If 1 doesn't work, backup your important data and do a factory reset.
  3. If 2 doesn't work, find a factory image of marshmallow and flash it.
  4. If you are not willing to do 3, wait for google to fix it.
Home PC: i5 6402P | Kingston HyperX 8GBx2 | Gigabyte G1 gaming GTX 1060 | Kingston UV400 240GB | WD blue 1TB Gigabyte H110m-S2 Cooler Master B500 v2
Laptop: Lenovo Yoga 710(Kaby Lake)
Phone: Oneplus 3
Tablet: iPad air 2
