Put new mother board into my pc. My old one was gigabyte z77-ds3h, new one is asus p8z77-v, and i plugged in all the cords right. but then when I went to turn my pc on my fans were at full blast. Went to windows recovery. Repaired it. Did not work. Went into bios says boot to drive, did not work. Then said "Error cpu fan", so somethings wrong with that.  And the H100i boots up either green or red led. When i try to boot into windows normal, it crashed right when the points of light happen on the screen.
System Specs
i5 3570k
Evga Gtx 660
16 gb of crucial ballistix ram
!tb segate barracuda
asus p8z77-v
inland 550 watt power supply.
I really need help, because only one of the h100i fans will work on when plugged into mother board.
https://linustechtips.com/topic/65923-need-help/
Make sure you have something plugged into the CPU_FAN header.
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/65923-need-help/#findComment-900801
Sometimes there will be issues when switching out motherboards, one of the issues may be that you'll need to re install windows.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/65923-need-help/#findComment-900823
