So during the past several months I have encountered this problem with my pc ONLY while playing CSGO. Randomly, usually in faceit/esea (these are separate leagues from the normal game) matches i will crash randomly: first my second monitor goes to a dark blue screen, and then shortly after causing my main monitor to go black. Sometimes my game comes back up from this and it doesnt fully crash the PC, but othertimes it reboots into the resolution that i use for cs, which is 1280x960 4:3. There are never any crash reports, and i have used EVGA's precisionX software to detect artifacts and such, and none ever appear. The same deal is with other benchmarks or games running in 1080p. I have no idea how this issue happens, or if anyone else has had the same problem or knows of a fix. If anyone does have a fix, help would be greatly appreciated.
System Specs:
EVGA GTX 970 SSC
I5 4460
16GBs of Ripjaws ram
evga 750w g2 psu
msi z97 g45 gaming MOBO
OS, WIN10
and CSGO is on my SSD whereas other games are on the HDD.
Thanks again for any help :/
https://linustechtips.com/topic/659082-weird-system-crash-while-playing-csgo/
Have you been overclocking?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I've had a weird, similar thing happen to me with Source games and Unigine benchmarks. It turned out to be the firewall. So, if you're using an aftermarket firewall, try setting it to gaming mode.
CPU: i7 4770K  |  Corsair H80i  |  ASUS Z87-Pro  |  8GB Corsair 1866Mhz  |  GPU: MSI Gaming X RX 480 8GB  |  Corsair HX  750
hey guys thanks for the replies, and no i have not overclocked anything, the gpu already boosts up to 1392mhz and i dont need it to get any hotter. Also im using windows defender, which doesnt have a gaming mode. I've been thinking it could be due to my hdmi connection on my second monitor, as when i unplug it i get similar glitches with my screens, just a thought though.
First step would be to replace the HDMI cable. Next step would be to disable your firewall, if the issue happens often, and verify that it could be.
