Weird if its true what your saying, a 1070 should throttle at >85C
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
Power throttling? CPU bottleneck?
thats most likely it.
Just now, TheScottishNerd said:
cpu is i7 3770 k but when im in game the cpu never hits 100 percent load its always around 60 -70 in overwatch it sits at 50 but the fps goes right down once the gpu hits 75 oc
Have you accidentally set the GPU to throttle at 75*C? Remove your Overclock.
40 minutes ago, TheScottishNerd said:
on msi afterburner temp limit is 83 oc
The temp limit on it's own won't do nothing.
On afterburner, use a custom fan curve that kicks fans to 85 to 90% speed since you hit around 70c. Otherwise it will not increase fan speed and it will decrease frequency instead. I much rather have a slight noise (I really can't hear it over my game sounds over the speakers, but I do have a noisy room) than crap framerates.
Current Rig
54 minutes ago, TheScottishNerd said:
but with the fans at that speed is it safe for long peroids or time ?
Yes, it just sounds like a jet engine
