i wanted to know how much ram will i need for my usage
my usages
i) i do 3d animation for 2/3 of a day
ii) i always have two media players playing some movie or song
iii)i also do video editing some times with some effects
AND the final
iv)and i have 2 browser running with 30 tabs open in each of them
i do all this together so yeah
https://linustechtips.com/topic/65811-need-help-in-selecting-ram-size/
Well I'd personally recommend at least 16GB, but it depends on your budget. If you can afford it, get more. I know After Effects eats up all my 8GB of RAM easily :P
CPU: Intel Core i5 2550K @ 4GHz | Cooler: Gelid Tranquillo Rev. 2 | Mobo: Gigabyte GA-Z68AP-D3
GPU: XFX 1GB HD6850 OC'd | SSD: OCZ Agility 3 60GB | HDD: Samsung 500GB | PSU: Corsair HX520W | Case: Zalman Z11+
Just throw in 16GB if you can afford it and be set.
CPU: i5 4670k • Cooler: Corsair H100i • Motherboard: MSI Z87 MPOWER • RAM: Crucial Ballistix Elite 2x 8GB • Storage: Samsung 840 250GB SSD, 2x WD Red 3TB • GPU: EVGA GTX 780 3GB • PSU: Corsair RM750W • Case: Corsair 750D • Mouse: Razer Naga 2012 (I actually use the thing for productivity/media buttons) • Keyboard: Ducky Shine 3 w/ Browns - Green LED • Monitor: Asus PB278Q 27" 2560 x 1440, ASUS PB238Q 23" 1920x1080 • Lighting: 2m NZXT Sleeved Blue LED Strip • pcpartpicker.com/p/3cHfZ
look on your motherboard manual to see the recommended module kits for your m/board and get the fastest and max amount you can afford to buy, best with bigger capacity modules then you can upgrade if you need in the future if you have any free slots.
Atleast 16 gig if not 32 gig kit to be safe.
what motherboard do you have?
got to love Asus components
http://pcpartpicker.com/part/mushkin-memory-997074
cheap 16gig kit, cant go wrong on this price.
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
Go for either a 16 gb kit or a 32 gb kit, and aim for something like 1600mhz or 1866mhz. 32 gb would be preferable but if you don't want to cough up the cash 16 gb should still get the job done fine :)
CPU Overclocking Database <------- Over 275 submissions, and over 40,000 views!
GPU Overclocking Database
for 3d animation the more ram you have the faster you do rendering. Go for the maximum that your motherboard supports
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
