PicoPSU Help
Go to solution Solved by W-L,
3 hours ago, HeroXLazer said:
Yeah that looks good within the voltage and amperage range for the input of the unit, and a little bit of overhead.
6 minutes ago, HeroXLazer said:
Where can I get an AC-DC power brick for the PicoPSU X300 and I need all 300 watts. I only want to use trusted source.(ebay, amazon, etc.).
For something like that your not going to be able to find regular AC to DC power bricks for laptop since most don't come in such high wattage unless you have two units feeding it in parallel.
http://www.digikey.com/product-detail/en/delta-electronics/MDS-150AAS24-BA/1145-1013-ND/3909338
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8507748
Highest is 240W, I have been looking for the last hour or so.
Not to sure what you would need to do in order to parallel two adapters.
I have put in series 3 MeanWell power supplies to up the voltage, but parallel ups the wattage power. Maybe just a common ground.
Maye use one adapter to power half of what you got, then the second adapter to power the other half of what you got.
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8507826
How would I be able to use 2 power bricks?
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8518555
I doubt power bricks aka adapters are an issue. Its the DC-DC ATX wattage that is the issue.
Not per say what the ideal is, but thinking outside the box.
http://ca.mouser.com/Power/Power-Supplies/Switching-Power-Supplies/_/N-axgkh?P=1yxt78xZ1yxt777Z1yxt5vgZ1yxt774Z1yot90qZ1z0wc6aZ1z0x08cZ1yndk21Z1z0wbk1Z1z0wc7oZ1yot959Z1z0wc7vZ1yot95bZ1yot8zr&Ns=Pricing|0
MW SE-600-15 at
247 mm 127 mm 63.5 mm
for $130cdn
I remember reading some forum board "guru" elsewhere, series and/or paralleling multiple adapters. But who knows what the size difference is.
It was all about grounding the units.
Even mousers AC Adapter is peaked at 300W. Two units are 280W and is $130cdn, then the price jumps more then double. Even filtered down to 250W, cheapest is still $130cdn.
I think those Pico PSU's are made for low power, unless you custom make something, like custom dual bricks interconnection and a custom converter architecture. Not sure if its just suppling the voltage required, or if there is more to it like signal quality, and grounding. Probably very technical. But even the Pico PSU's are tiny, the PCB boards anyway. Otherwise just a splitter from 19V to the required would be needed.
I found this website, using high wattage DC-DC converters. Looks like an interesting way to go.
http://trcelectronics.com/dc-dc-converters-bricks.shtml
http://ca.mouser.com/Power/DC-DC-Converters/_/N-brvxe?Rl=brvxeZerbiZ1z0wav2Z1yot976SGT&Ns=Pricing|0
400W $95cdn
The DC-DC is more logical way to go.
If you want to find a video on connecting 2 laptop adaptors up together, look at the Ypedal Youtube channel.
He series them though.
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8520820
4 hours ago, HeroXLazer said:
 I just DMed someone on this site who may know where to get a 350 watt external power brick.
That's a nicely machined build, but here he used a 20V 350W Gigantic external brick, which would be very costly to two desperate power bricks as he points out.
https://linustechtips.com/main/topic/291439-build-log-h2o-micro-3-liter-watercooled-gaming-system/?page=5#comment-4646728
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8521204
What about this?
https://www.amazon.com/gp/product/B00CK2TY12/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&tag=notfromconcsy-20&camp=1789&creative=9325&linkCode=as2&creativeASIN=B00CK2TY12&linkId=be7cbca9f9a1bd9d7038a1eebefa2538
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8526817
https://linustechtips.com/topic/657905-picopsu-help/#findComment-8528362
