Hello the people of the Internet, I live in the USA and have a budget of 1300$ ISH. 1300$ for the PC You can go over with the monitor. I will primarily be using this PC for hardcore gaming and streaming. I want to play at 1440p so I will need a new monitor too, other then that I need no more extra things. I really want a black with a white accent build. My requests are window to see the guts of the computer, a black case, and I will try to over clock some. I would also like to water cool. Keep in mind this will be my first PC build alone. Thank you for reading and I will be asking some questions in comments depending on your build suggestions!
https://linustechtips.com/topic/657847-streaminggaming-pc-help/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Corsair H100i v2 70.7 CFM Liquid CPU Cooler  ($96.99 @ Best Buy)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($137.98 @ Newegg)
Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-2666 Memory  ($85.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($94.00 @ B&H)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($47.49 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB Founders Edition Video Card  ($449.99 @ B&H)
Case: NZXT H440 (Matte Black) ATX Mid Tower Case  ($96.99 @ Directron)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1307.41
Generated by PCPartPicker 2016-09-09 21:21 EDT-0400
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8506750
Total: $1307.41
b-b-b-b-b-b-b-b-b-but that psu thooo, weak (jk i just like when ppl say how weak psus are)
MF UH BEANS
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8506868
Total: $1307.41
What made you choose that mother board over any others and why a founders edition card when there is after mark ones that have higher base and boost clocks?
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8507164
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ SuperBiiz)
CPU Cooler: Phanteks PH-TC12DX_BK 68.5 CFM CPU Cooler  ($46.99 @ NCIX US)
Memory: Crucial Ballistix Sport LT 16GB (2 x 8GB) DDR4-2400 Memory  ($71.99 @ B&H)
Storage: Samsung 250GB 2.5" Solid State Drive  ($69.99 @ B&H)
Storage: Western Digital Blue 1TB 3.5" 5400RPM Internal Hard Drive  ($53.68 @ OutletPC)
Video Card: EVGA GeForce GTX 1070 8GB FTW Gaming ACX 3.0 Video Card  ($446.98 @ B&H)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ NCIX US)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.49 @ SuperBiiz)
Monitor: Asus PB278Q 27.0" 60Hz Monitor  ($389.99 @ Newegg)
Total: $1721.07
Generated by PCPartPicker 2016-09-10 00:11 EDT-0400
aircooling should be enough, if you don't go over 4.5 GHz. The Hyperthreading should help with streaming.
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8507927
Total: $1721.07
How much would faster ram effect streaming?
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8510597
It is not that much, some low %. It is more about having DDR4 Sticks that are fine with OC and the XMP Profile. Especially since you first had 2666 Sticks, but the 2400 are often not end of line and can go even higher then 2400 while ofc reducing CL.
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8510893
Ok, so I can do some decent over clocking with that air cooler?
https://linustechtips.com/topic/657847-streaminggaming-pc-help/#findComment-8511007
