Hi im being a given a 6th gen intel motherboard in the next few days for free but i do not own a 6th gen cpu to test the board, i wanted to test if things like pci lanes are running a gpu as i know sometimes that can be a problem, but i want to know that if i give power to the motherboard will it for one actually run (i dont need it to boot) and will it run the gpu if power is supplied to it aswell. or is the only way to test it through installing a cpu?
Cheers
https://linustechtips.com/topic/657515-motherboard-testing-without-cpu/
There are some "fake" CPUs that will allow to boot up the motherboard to make sure that it works.... A motherboard will work though so long as there are no bent pins.... Make sure that there are no bent pins in any of the slots and in the socket and you are golden...
If you want, you can buy a cheap Celeron for $40 and then sell it on eBay....
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
alright cool the motherboard is in perfect condition but im planning to sell it straight on anyway so i didn't want to have to buy a cpu so im glad thats the case
