Sorry but the motherboard you have does not support WiFi by itself. You'll need to buy a USB WiFi dongle. NOTE: Do not buy a PCI-E card, as they waste your lanes.
i5-8600K -  Asus Strix Z370E - Asus GTX 1060 Strix - EVGA 650W P2 - Samsung 970 Pro 500GB - G.Skill TridentZ 16GB
https://linustechtips.com/topic/656655-motherboard-help/#findComment-8489587
It first depends on what you need and what your config supports.
Do you have or plan on getting wifi AC?
What about 5Ghz?
3x3 AC dongles are out there but those are way more expensive.
If you can, wait for a good product on sale. Make sure it is USB 3 and you should be golden. Read reviews of product ofc.
https://linustechtips.com/topic/656655-motherboard-help/#findComment-8491926
