Just now, Andrew Rackley said:
it is the one that comes with the computer so some offbrand one
is there a sticker on the side of the psu?
https://linustechtips.com/topic/656650-i-need-help/#findComment-8489430
yes it says made in china and the wattage that is all it says
no model names, UL code, anything else? if not, i'd recommend you swap it to something else. also, make sure your hp can fit the gtx 750ti before you buy it.
https://linustechtips.com/topic/656650-i-need-help/#findComment-8489457
yes it can fit the gpu but all the psu i see dont have the connectors i need on my motherboard
https://linustechtips.com/topic/656650-i-need-help/#findComment-8489473
if you can't find any info other than made in China (10/9 of everything is made in china :P) then get a new psu. something like this antec vp450 will do just fine(make sure your mobo isn't using some proprietary crap). http://pcpartpicker.com/product/MnR48d/antec-power-supply-vp450
https://linustechtips.com/topic/656650-i-need-help/#findComment-8489539
Just now, dexxterlab97 said:
you need PCI E 16x on your motherboard to use a dedicated gpu
750ti uses 6 pin connector. check if your psu have it. look for one with
only a few models of gtx 750ti need the 6-pin connector, others don't have it.
https://linustechtips.com/topic/656650-i-need-help/#findComment-8489552
Lite-ON OEM, i'm not sure about their quality, @STRMfrmXMN should know something about it(or lite-on as a whole). if it checks out fine, then any gtx 750ti without the 6-pin connector should be fine with it, but if you're adamant about the EVGA SC than get a new psu.
https://linustechtips.com/topic/656650-i-need-help/#findComment-8489716
32 minutes ago, Andrew Rackley said:
i dont know that is why i am on this forum
This PSU is what I call a "fireworks look much better outdoors."
https://linustechtips.com/topic/656650-i-need-help/#findComment-8490003
new psu it is then. antec vp450? or if you can, spend some more for a cx450m.
https://linustechtips.com/topic/656650-i-need-help/#findComment-8490035
