I use Ethernet on my pc and today I turn it on and now it wont work I don't know what to do I don't get any Ethernet connection but I do get Ethernet connection to my xbox and my tv so I know that's not the problem but it seems to not wanna come online so I need help I also have a note under my Ethernet connection (2) properties that ses this network connection is disabled or has been removed from the system you must reinstall the driver or enable it from general tab before you can access disable features and their is a note it said this device supports a low power  mode that causes the operation system  to behave as if the device has been removed if the network cable is not attached to the device  connecting cable may enable it
https://linustechtips.com/topic/656317-no-connection-help/
so so then reinstall the driver or re-enable it as it seems its disabled and it should work. unless your really not explaining your self right.
Please Quote so i know you have replied. | If we have provided a solution to your problem mark it with answer found.
And also please read the COC and avoid the embarrassment and lecture that will ensue.
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8481887
so do i uninstall the drivers then reinstall them and it doesn't give me an option to re enable it
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8481939
yes that's the first step if that does not work i would then suggest you update the drivers but before that in the device manager is there a code on the device?
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8482165
I don't see a code  but after I'm done unistalling the drivers do I reset my pc and let them reinstall
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8482190
also there is a file in driver file details it said unknown provider unknown file version unknown copyright
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8482227
Thats fine it could just be a corrupt driver, is all.
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8482245
Windows should have default drivers to install
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8482947
3 hours ago, MR.Grayhat said:
 try reinserting the wireless card  look at the pins for scratch'sand if u got a spare wireless card laying around try that one if it dont work  i dont really know what to do then
I already tried the one that's in my xbox and it works on xbox so its not that
https://linustechtips.com/topic/656317-no-connection-help/#findComment-8485142
