hi i am going to build a new pc for the first time and wanted some thoughts on it. it will primarily be used for gaming and recording
i am building it because all i have is a laptop and it is no use for gaming
the parts are : processor = amd fx 8350 (will maybe overclock when i get a better cooler)
                   motherboard = asus m5a97 r2.0
                  graphics card = vtx3d radeon 7870 tahiti le
                                  ram = corsair vengeance 2x4gb 1600 mhz kit
                        hard drive = seagate barracuda 500gb
                                  psu = corsair builder series 500w semi modular
i dont need a monitor and i dont need a keyboard and mouse.
i will only be gaming using one monitor too
https://linustechtips.com/topic/65622-first-build-thoughts/
What's your budget?
My Pc: Cpu: I7 4790k @ 4,8 Ghz @1,25 volts, Motherboard: Maximus VII Formula, Graphicscard: 2x Titan X @1,4 at stock voltage (soon to be replaced), Ram: 32 gb Corsair Dominator Platinum 2133 Cl 9, SSD: 2x 850 Pro 1 Tb in Raid 0, 2x Samsung 840 Evo 1 tb raid 1,, PSU: Corsair HXi Series 1000W 80+ Platinum, Case: H440. Soon to be watercooled again, maybe, probably, the Titans are too loud.
https://linustechtips.com/topic/65622-first-build-thoughts/#findComment-896533
-Get a 1TB HDD for like £10 more.
-Save £30 and get a 8320
-Put the extra £30 into a 7950
Other than that pretty good.
CPU: Ryzen 5 3600 @ Stock, CPU cooler: Dark Rock 4, Motherboard: MSI B450M PRO-M2 MAX, RAM: 2x8GB Crucial Ballistix DDR4 @ 3000Mhz, GPU: EVGA GTX 1080 ACX 3.0, SSD: Crucial P1 1TB M.2 + 2x120GB SSDs, Case: Corsair 110R, PSU: Corsair TX650M, OS: Windows 10 64-bit.
https://linustechtips.com/topic/65622-first-build-thoughts/#findComment-896541
I agree with classics, better safe than sorry when it comes to HDD space. Also it is worth the wait for slightly better components in my opinion.
I am on my second build atm, but for my first one I cheaped out on parts and regreted it. Patience is one feature in a system builder that rewards you for every second.
Also, we would like to know your budget please.
https://linustechtips.com/topic/65622-first-build-thoughts/#findComment-896554
8350 is better and the tahiti le version of the 7870 when overclocked is about the same as the 7950 an i think i will get the 1tb hdd
https://linustechtips.com/topic/65622-first-build-thoughts/#findComment-896633
8350 is the same chip, just stock clocked 0.2Ghz higher.. And you could OC a 7950 and get similar performance to a 7970.
https://linustechtips.com/topic/65622-first-build-thoughts/#findComment-896735
No case?
https://linustechtips.com/topic/65622-first-build-thoughts/#findComment-902430
