Evolv ITX Bracket Stuck!
Go to solution Solved by the7sensez,
Any hidden screws or something in the way? Or maybe it's just stuck, there are these rare times when you just need some lubricant and to gently rock the stuff back and forth.
It might be a case of cold welding, but only if you've taken your rig to space recently :D
https://linustechtips.com/topic/656101-evolv-itx-bracket-stuck/#findComment-8475701
Found one hidden screw that I completely missed.  Thanks
https://linustechtips.com/topic/656101-evolv-itx-bracket-stuck/#findComment-8475718
