Posted September 7, 2016 For my second of build, I want to watercool the CPU for overclocking. I don't know if u should use a all in one water loop, or I should make my own water loop. http://pcpartpicker.com/user/Jonwong966/saved/kFB323 My cooling budget is about $200 USD Link to comment https://linustechtips.com/topic/656077-water-cooling/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 h115i is a good cooler to let you overclock your cpu. Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8474757 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 4 minutes ago, PCNoobie said: h115i is a good cooler to let you overclock your cpu. +1 on that Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8474816 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 200 dollars is not really enough for a custom loop. I'm going to go with an AIO. Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8474906 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 I'd also say to go with the H115i. Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8474961 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 Corsair is never a bad choice, but any 2x 120mm or 2x 140mm cooler that has good reviews and you like the look of will handle overclocking of that CPU just fine. That being said, you could look at the EK Predator. Its an expandable AIO so if you ever wanted to add another radiator and a gpu to the loop, you can, and it's under 200 for the 240mm model. Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8475022 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 For $200 it might be better to get an AIO. A good pump for a custom loop can cost up to $100 alone plus the cost of a high performance CPU block would already put you over budget. CPU: Intel i7 4770k 4.3ghz MOBO: Asus Z87 Sabertooth RAM: 2x8GB RipJaws 1866mhz GPU: 2x GTX780ti SLI 1.2ghz SSD: 960GB 2x Intel 730 RAID0 CASE: Fractal Design Define S COOLING: Custom EK watercooling loop Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8475659 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 7, 2016 I'd say get a decent AIO water cooler. I recommend the Corsair H115i, just put some better fans on it (Corsair's new ML pro series fans are AWESOME). If they are like the fans that came with my H80i, they are loud AF. I'd also like to do a custom loop for my PC, but it is not necessary for the hardware I'm currently packing. ZamoRIG 2.0: Processor: AMD Ryzen 7 1700 @ 3.9GHz Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans Graphics Card: Gigabyte GTX 1070 G1 Gaming x2 Motherboard: Asrock X370 Gaming K4 RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz SSDs: 2xPatriot Ignite M.2 240GB HDD: WD Black 1TB + WD Green 2TB PSU: Corsair RM750 Case: Corsair Carbide 400C ZamoRIG “Portable”: Processor: AMD Ryzen 5 1600 @ 4GHz Cooling: Corsair H80i Graphics Card: Gigabyte GTX 1070 G1 Gaming Motherboard: Gigabyte AB350N Gaming WiFi RAM: 1x16GB DDR4 Corsair Vengance @ 2400MHz SSD: Patriot Ignite M.2 240GB HDD: 2TB 2.5” Seagate HDD PSU: Corsair TX650M Case: Siverstone SG13 Link to comment https://linustechtips.com/topic/656077-water-cooling/#findComment-8476317 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
