1. Budget & Location
I was thinking 10k NOK as maximum.
Location is Norway.
2. Aim
Some gaming, some computer science work.
3. Monitors
I plan on running 2 monitors.
Packard bell Viseo 243D is what I am using atm.
4. Peripherals
No peripherals needed!
5. Why are you upgrading?
Because my system is getting old. It was built on a budget 2 years ago.
Here's a list of the parts I have:
Intel Pentium G3258 3M Cache, 3.20 GHz
MK ASRock Z97M Anniversary
Super Flower Golden Green HX 600W 120mm Fan 80+ Gold ATX
DDR3-DIMM2133 Team Zeus 2x4GB DDR3 2133MHz Blue Heatsink
MSI GeForce GTX 760 GAMING OC TwinFrozr IV 2GB DDR5 2xDVI HDMI DisplayPort PCIe
Tower Fractal Design Arc Mini R2 Tower Black No PSU mATX
Cooling-CPU Cooler Master Hyper 412S
HDD-SSD Crucial MX100 256GB SSD R:550/W:330 2.5" 7mm SATA-3
Is anything worth keeping?
Thanks in advance!
https://linustechtips.com/topic/655716-need-some-help-deciding/
16 minutes ago, Isvan said:
Just for others, 10,000 NOK is about 1223.14 USD FYI
Are you going for all new parts, or will be looking second hand as well?
Thank you!
I should have added that myself.
Preferably new parts, but I haven't ruled out second hand.
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8463397
Location is Norway.
2. Aim
3. Monitors
4. Peripherals
Thanks in advance!
There isn't a PCPartPicker for Norway, You fine with German PCPaartpicker or do you have a similar thing in Norway.
Used to be Buizel10. Forgot email password and LTT password. Check that account for my info.
O Canada ---- Vancouver, BC ----- Live 40km from LTT Office
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8463491
German would probably be fine.
Unless you could use prisjakt.no when you search for parts. It functions as pcpartpicker, if I'm not mistaken.
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8463537
ill see whats cheaper
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8463647
5 minutes ago, brob said:
Have you considered just getting an i5-4690K and a better gpu, perhaps a GTX 1070?
I have thought about something like that, but I do want to be able to run 1151 or similar sockets, utilizing ddr4 ram.
Might make it harder to figure out, but I'd rather have something I'm able to easily upgrade again later.
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8464130
Regardless of what you do, you will be faced with exactly the same decision the next time. LGA-1151 and DDR4 is hot right now, in 2 years time, it will old and out of date. There will be something else that is much better.
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8464435
On 9/6/2016 at 1:20 PM, Jern said:
That doesn't have to be included.
Ok sorry for late reply. I will make tommrow afternoon because it is 10:30pm now
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8551856
http://de.pcpartpicker.com/list/sX2vjc
PCPartPicker part list: http://de.pcpartpicker.com/list/sX2vjc
Price breakdown by merchant: http://de.pcpartpicker.com/list/sX2vjc/by_merchant/
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (€352.83 @ Mindfactory)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  (€87.99 @ Aquatuning)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  (€77.99 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (€54.05 @ Mindfactory)
Video Card: Gigabyte Radeon RX 480 8GB Video Card (2-Way CrossFire)  (€278.04 @ Amazon Deutschland)
Other: CHOOSE A CASE (€75.00)
Total: €1203.94
Generated by PCPartPicker 2016-09-18 19:24 CEST+0200
11124 NOK according to google
EDIT:   accidently DDR4, just choose any ddr3 16gb
https://linustechtips.com/topic/655716-need-some-help-deciding/#findComment-8565107
