Custom Audio Drivers ...and stuffs
Okay programmers, i have a question.
i want custom drivers/firmware for my sound card and have had zero luck finding anything on the interwebz. basically what i want to do is boost the output past spec, if it burns up i could care less, its a rocket fish 5.1 from best buy, like 20 bucks.
any ideas where to start?
i have almost zero programming knowledge, but i can learn.
i am also looking to crack my Logitech x-540's open and start replacing pots, resisters, coils and anything else that looks like it needs an upgrade. and if they dont work when im done, OH WELL! they are like 4 years old and gotta go if i cant make them better.
https://linustechtips.com/topic/65489-custom-audio-drivers-and-stuffs/
Just upgrade straight away...
What you're trying to do is:
^^ This
I have never heard of custom audio drivers, or custom drivers of any sort before, I really doubt it can be done, however if you do find out how, post the link here, because I am a bit curious now :P
Intel 3570K - MSI GTX 660Ti 3GB OC Edition - 16GB Corsair LP RAM - ASRock Extreme4 Motherboard - Corsair HX850 - Adata Premier Pro SP900 120GB SSD with Windows 7 - Seagate Barracuda 1TD HDD - Seagate Barracuda 500GB HDD - Thermaltake Frio CPU Cooler - CM Storm Enforcer Case - Macbook Pro Early 2011 Laptop
^^ This
There are custom graphics drivers, in Linux for instance.
@sTizzl
You can create your  own drivers, but it's not easy at all.
You have to know how to build/compile drivers for your architecture/OS and, more importantly, reverse engineer the communication protocol for your card.
But I'm not sure you can boost whatever with the drivers. Maybe changing the firmware on the card, but that's a whole other subject, possibly even more complicated than the drivers and probably impossible.
you can do it, but it's not recommended, or easy
[spoiler=»--((¯`·._.·¤~●oO му яιg Oo●~¤·._.·´¯))--«] Case: Corsair 600T White       CPU: Core i7 3930k @ 4.3GHz                     SSD: Crucial M500 480GB
MB:    Asus P9X79 LE         GPU: Nvidia GTX 780 Reference             HDD: WD Caviar Green 3TB
PSU:   Seasonic X-1050      RAM: G.Skill Trident X 32GB @ 2.4GHz   ☃ There are 10 types of people in this world. Those who understand binary and those who don't.
