So recently I watched a video from Tek Syndicate saying that the AMD FX 8350 seems to be better when it comes to streaming than the i5 but my problem is:
Current Spec:
8GB Ram
Intel I3 2100
Gigabyte H61M USB 3 UD3
AMD 7870 XFX Ghz
I would like to start streaming games like DayZ Which if you don't know if very hard on the processor
My question is should I get the I7 3770k with this current motherboard or should i get the AMD FX 8350 with a new mother board such as
AsRock 990FX Extreme3 Motherboard: http://www.amazon.co.uk/ASRock-990FX-EXTREME3-Extreme3-Motherboard/dp/B005POPQZA/ref=sr_1_1?ie=UTF8&qid=1381747555&sr=8-1&keywords=990FX  or
MSI 990FXA Motherboard  : http://www.amazon.co.uk/MSI-990FXA-Motherboard-Processor-Gigabit/dp/B004ZHC2DC/ref=sr_1_4?ie=UTF8&qid=1381747555&sr=8-4&keywords=990FX
Sorry for the long winded question hope I can receive some help.
Also if you think i should go with the AMD then maybe suggest some other MOBOS
Thanks
https://linustechtips.com/topic/65447-looking-for-some-help-between-amd-and-intel/
Current Spec:
8GB Ram
Intel I3 2100
AMD 7870 XFX Ghz
Thanks
well yeah its better with x split it depends if u wanna do that or not but if ur streaming then yeah go with 8350 ...
its cheap too so could save some money
+ r u thinking about over-clocking if not ill go for a cheaper mobo ...
CPU: Fx 8350 | CPU Cooler: Coolermaster Hyper 212 Evo Now  AMD STOCK CPU COOLER | Motherboard: Gigabyte GA-970A-DS3 (rev 1.1)   NOW MSI 990FXA-GD80 | Ram: Corsair Vengence 8GB DDR3 Motherboard detects 7gb for some weird reason | Graphics Card: SAPPHIRE HD 7870 GHz Edition 2GB GDDR5 |  HDD: 1 TB samsung
Case: CM elite 310 | Monitor: Aoc e2050S
OS: Windows 8 Professional 64 Bit NOW  Wndows 10 Professional 64 Bit
 Power Supply: Cooler Master Thunder 500W NOW GX 650W v2
3770k is your best option since you already have a mobo and the 3770 chip is a lot better than 8350
8350 8 "cores"(They are not not 8 real cores)
3770 4 real cores and 4 with hyperthreading
Also Intel is better everywhere else and I believe that 3770 and 8350 are about the same thing in streaming
"You can get more of what you want with a kind word and a gun than you can with just a kind word." -- Al Capone.
I believe you can't overclock a 3770k so a new motherboard may be needed. Intel is still a better choice in my opinion.
My Gaming Rig;  Motherboard - ASUS Maximus VI Hero | CPU - Intel i5 4670k @4.5Ghz 1.25v | GPU - GIGABYTE GTX 980 @Stock | RAM -  16GB Corsair Vengeance @1866Mhz | CPU Cooler - Corsair H100i | Storage #1 - Samsung 840 Basic 250GB SSD | Storage #2 - Sandisk II 480GB SSD | Storage #3 - 2TB 7200rpm 64mb HDDPSU - Corsair HX750 | Case - Fractal Design R4 |
This choice should be depend on your budget, not which company your prefer the most, otherwise you will not receive the best performance for the budget you are willing to spend. For lower budget systems, go with AMD, no questions asked. Their processors and APUs provide the best price to performance and will exceed processors from Intel at the same price point. However if you have a large budget Intel is the way to go, if you can afford to buy an Intel processor you will see a performance increase over the same tier AMD CPU. This is excellent for higher end PCs which need the extra performance. If you want a satisfactory experience you will have to buy a new motherboard, which motherboard and socket should depend on your budget and which side you choose.
Sam,
Intel Response Squad member
http://bit.ly/IntelRally
Well they are both the same price if I buy the AMD and a mother board or just the I7 the problem I have is I don't have enough money for I7 and motherboard at the moment so would it be better to get the AMD as i get a more future proof motherboard? thanks for the quick responses
Current Spec:
8GB Ram
Intel I3 2100
AMD 7870 XFX Ghz
Thanks
You already have a mobo and i would say "go Xeon e3-1230v2" but your mobo only supports the v1 which is sandy bridge.
Thus, I would say:
go for 3770 (not a "K" version since you cant overclock it anyway with this mobo), will be a bit more than a Xeon e3-1230v2 but you cant use that xeon with your old mobo.
Overclocking i7 doesnt give you as much performance to be worth it in your case and i7 is superior to AMDs fx 83xx overally.
Just get i7-3770.
][ CPU: Phenom II x6 1045t @3,7GHz ][ GPU: GTX 660 2GB ][ Motherboard: Gigabyte GA-MA770T-UD3P ][ RAM: 8GB @1450Mhz CL9 DDR3 ][ PSU: Chieftec 500AB A ][ Case: SilentiumPC Regnum L50 ][ CPU Cooler: CoolerMaster Hyper 212 Evo & Arctic MX4 ][
Thus, I would say:
Just get i7-3770.
This.
This.
Or this if he wants to save a bit money by going with Sandy Bridge i7 (a tiny bit slower and more outdated than ivy bridge i7 but cheaper):
http://pcpartpicker.com/part/intel-cpu-bx80623e31230
Think I will go for the I7 Because I fell more confident purchasing that because more reviews on Amazon.
i choos AMD cuz of the price but the fx 8350 is fast and i run bf4 smooth with it no problems my friends with the same videocard and intel corei7 3770k is not running as good as I am :)
Cpu: intel i7 4790k    Motherboard: MSI GAMING 5   GPU:Nvidia GTX 980Ti   PSU: Corsair AX 760 PSU  RAM:Crucial DDR3 Ballistix Tactical 24GB RG  SSD: OZC Vertex 4 128GB  HDD: 2x1tb WD  Case: Thermaltake Level 10GT Snow edition!
I Don't see how your friend is struggling because I can Run at around 55-60 FPS and im using Intel I3 and the 7870 maybe its his drivers
Good choice, now you re only a few parts a short of a nas / of sense box / other PC. You couldn't t say that about having only a CPU left out....
He s probably running win7...
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
dont know dont care my amd build is better then his intel <3 so fuck him xD
Hey dude watch your language in the forum. We are not trying to be Tom's Hardware over here!
Also stop being a fanboy please.
Edited by MikeTz
AM3+ isnt future proof its actually ancient. and there is strong talk that AM3/3+ is EOL
Processor: Intel core i7 930 @3.6  Mobo: Asus P6TSE  GPU: EVGA GTX 680 SC  RAM:12 GB G-skill Ripjaws 2133@1333  SSD: Intel 335 240gb  HDD: Seagate 500gb
Monitors: 2x Samsung 245B  Keyboard: Blackwidow Ultimate   Mouse: Zowie EC1 Evo   Mousepad: Goliathus Alpha  Headphones: MMX300  Case: Antec DF-85
I know it involves reading but something to consider and ponder : http://www.tomshardware.com/reviews/storage-controller-performance-ssd,3540.html
Sorry for the homework but its best if you read it yourself and digest without my interference.
I roll with sigs off so I have no idea what you're advertising.
This is NOT the signature you are looking for.
wrong..they are all real cores. just because they dont follow the same build structure as intel doenst mean its "fake" or "not real".
there are threads on this forum that actually explain that they are real.
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
It has 4 modules with 2 "cores" inside,but 1 module from AMD is 1 real core from Intel.
That is why a 4-core CPU from Intel is better than an 8-core AMD CPU
Edit: Because of that AMD's 8-core CPU's aren't really 8 cores but 4 modules which have 2 computation cores inside
2nd Edit:You are right about the statement that I made that they are not real cores.They are actually real cores,just very weak.
Edited by MikeTz
wrong..
https://linustechtips.com/main/topic/48571-intel-amd-architectural-discussion-how-far-ahead-intel-really-is/
An AMD module packs more performance than intel core which takes roughly the same die area.
So architecturally speaking, Intel isn't really ahead of AMD nor is AMD ahead of Intel so to speak, the parallel nature of the AMD modules gives them the pure performance advantage over the intel cores, however what intel lacks in total CPU throughput makes up in single-core throughput.
In an absolute sense an AMD module can process more data faster than an intel core, however there is a sacrifice which is single-threaded performance.
Although the majority of CPU-intensive programs are already multi-thread reliant & the ones that aren't are becoming so which will in turn make this sacrifice worth it for AMD.
The reason why Intel stuck to single-threaded performance focused CPUs is because it's easier to write code for one thread as opposed to two but it's becoming extremely difficult to push more performance out of a single thread which makes the move to higher parallelism inevitable.
also about true cores : https://linustechtips.com/main/topic/43829-the-difference-between-amd-cores-and-intel-cores/
wrong..
Look, I bet I can find some other post or article or whatever that says otherwise.
Either way the point is that Intel takes the crown for better CPU's and is the better option for the OP.
Lastly all the benchmarks that show that AMD is better are synthetic and DO NOT represent real world performance,
also the games that were tested are all the same all the some favor AMD and some favor Intel.
Intel is better in general and AMD is better in special occasion,that is a fact.
