Need help taming a process.
Here's the deal: there's this annoying "System and compressed memory" that's eating up a ton of CPU cycles and I want to solve that. I've tried most solutions online (malware, disable windows tips, update drivers) and the thing still sucks up an entire core out of my machine - nothing worked. So I decided to get creative.
At first, I thought about trying to limit is CPU usage. Problem is, the thing is a SYSTEM level process, and none of the programs I tried could mess with it. I can't go into task manager and set priority to low either; again, it's a system level thing. And I don't feel confident enough to just delete the ntoskrnl.exe file that the process comes from, I fear I might brick my OS doing so.
So if anyone knows of a solution, I'm open for ideas. Please. There's just no reason for that thing to turn my 6600k into a triple core CPU rather than a quad core.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/653962-need-help-taming-a-process/
Make an image of your OS using Macrium Reflect to an external drive.
After that, go into safe mode and see if it's still there. If it is, it's system level and should require a reinstallation. If not, go ahead and reboot and delete it.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
