4 minutes ago, Mackan_G31 said:
I dont find any compatible CPU coolers for Corsair carbide spec-01 and Corsair carbide 100R, Max CPU cooler height is 15cm. Any help??
Noctua NH-C14S
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8392422
The specification listed for cooler height is very conservative.
There are plenty of people who used a 212 Evo which is 158mm tall in the case.
Here's a SR Slim which is 161mm tall in this build: http://forums.furaffinity.net/threads/gaming-machine-your-pc-specs-updated.1986/page-20#post-5473050
Edit: merged dupe threads.
9 minutes ago, Mackan_G31 said:
thx, I have i5 4460 aswell so i might choose the Cryorig H7.
Yes, it comes with thermal paste but why get an aftermarket cooler for a locked cpu?
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8392470
What cpu are you cooling? Where are you shopping/located? Budget?
I have i5-4460, and budget is around 50 USD
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8392492
I had merged your dupe threads and edited my post in that time--might want to refresh the page and scroll up to my previous post.
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8392501
im not sure what to get, i just need a new CPU cooler
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394607
Why? Do yo not have the stock cooler?
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394609
1 minute ago, Mackan_G31 said:
Im taking my CPU from my pre builded PC, and i dont know much about that CPU cooler so its safer to buy a new one, I think??
What's the prebuilt and what cooler does it have? If you're not sure, can you post a photo?
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394618
My Pre build is a Lenovo Erazer x310, and i dont know whats the coolers name and any thing else about it, but i know that it installs by screws
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394629
The cooler seems fine. Are you using a different motherboard?
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394639
Im changing the motherboard to a MSI B85M-E45.
My other post was that i was gonna move pre builded pc parts to a new case and MB, and the CPU cooler is the problem, the new case supports Cpu coolers up to 150mm but the ones i have looked at is higher than that. so thats why i need help, to find any that fits.
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394647
Have you tried reusing the cooler on the new motherboard? I'm not sure if it does since I'm not sure what the mounting system is like but it sits if it fits.
I think i found one, Cooler Master Hyper TX3 EVO should work for me
It does work. That being said, a $5-10 115x stock cooler off of eBay would also work.
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394662
Im going the safe way, im just gonna buy a new cooler since im buying other new parts aswell.
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394669
If your'e set on buying  anew cooler, the Rhea would work: http://pcpartpicker.com/product/zNJwrH/raijintek-cpu-cooler-0r100005
If you want a beefier cooler in case you'd like to reuse it in the future for oc'ing an unlocked chip, the Pure Rock is great option: http://pcpartpicker.com/product/cwPzK8/be-quiet-cpu-cooler-bk009
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394678
OK, thx
https://linustechtips.com/topic/653774-cpu-cooler/#findComment-8394695
