6700k not boosting
Solved by Imakuni,
Just now, RS2007GOD said:is thats the sace then why does boost not work underload? Cpu-z, core temp etc all show 4ghz only during aida64. only time it hits the 4.2ghz mark is when the system isnt under load.
Are you even listening to me? I just explained it to you: when your CPU is under load, it's supposed to run at 4.0ghz, not 4.2ghz. So if you are running Aida64 and applying load, it should run at 4.0ghz, and that's exactly what it's doing.
I'll repeat this once more: your PC is working as intended, whether you understand it or not.
