Hey, I am looking for a set of headphones for $100. I will use them for music and gaming, so the sound stage needs to be quite wide. (for gaming) I live in a relatively quiet area so opened back headphones would be okay however the ability to use them outside would be a plus. I also like strong bass. If anyone has any suggestions that would be awesome! Thanks in advance
https://linustechtips.com/topic/653274-help-finding-headphones/
M40x, HD280
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/653274-help-finding-headphones/#findComment-8387488
I'm just a random teenager from New Jersey. Why would you listen to me?
https://linustechtips.com/topic/653274-help-finding-headphones/#findComment-8387556
