Hi all,
So I will soon be travelling a lot and I want to bring my PC with me for the times when I am in the hotel.
Currently my rig sits inside a Define R4 which is too big to be carrying around, so I was going to go for a small mATX case, these are the parts I use
G1 Sniper M3
i5 2500 (Will be switching back to stock cooler for this case)
Nvidia 750Ti
16GB RAM
120GB Samsung SSD (May swap to my 500GB SSD for this build)
500GB 7200RPM drive
TP Link Archer T9E wireless card (Can use a USB dongle)
OCZ 750W ATX PSU
So I have seen a cheap case on Overclockers https://www.overclockers.co.uk/kolink-satellite-micro-atx-cube-case-black-ca-005-kk.html
This case seems decent but I am unsure if it will hold my build.
I dont want to spend a lot, ideally £40 is my budget.
What can you suggest?
Thanks
What does an Transformer get? Life insurance or car insurance? - Russell Howard - Standup (Made me giggle a bit)
https://linustechtips.com/topic/653226-small-matx-case-for-my-pc/
2 minutes ago, XDroidie626 said:
Hi all,
G1 Sniper M3
Nvidia 750Ti
16GB RAM
500GB 7200RPM drive
OCZ 750W ATX PSU
Thanks
That kolink thing only supports certain mATX motherboards. Make sure it's the right dimensions.
USEFUL LINKS:
PSU Tier List F@H stats
I swear by the Core 1300 in the UK
It's way better for cable management than the 1000 and 1100, and keeps the same design and good build quality for the price.
http://uk.pcpartpicker.com/product/PZx9TW/fractal-design-case-fdcacore1300bl
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
Bit big for a suit case PC though?
Ah! For a suitcase PC, those cubes are just as bulky, except in different dimensions. See if you can find a mini-ITX motherboard with the right socket, and buy a low profile cooler. Then use something like this:
http://uk.pcpartpicker.com/product/zmgPxr/silverstone-case-sstrvz02b
7378738a027a620637555fed3136ce92.1600.jp
Computer Specs:
I take it the PCI is on a riser, but how does the PSU work
The AvP Hyperion is fantastic little case for UNDER £25. Comes in black or white, and is chambered.
Has some fan options, though 80mm exhaust fan is questionable, but it compensates with side-fan options and intakes at the front which are 120mm or bigger. Uses mATX boards and normal size PSUs. Supports smaller GPUs mind.
http://www.ebuyer.com/724862-avp-hyperion-ev33b-black-cube-case-cas-107?mkwid=s_dc&pcrid=51482418059&pkw=&pmt=&gclid=Cj0KEQjwxqS-BRDRgPLp0q2t0IUBEiQAgfMXRJS1viNXj7w1a3_WwVgGMZMqixmK_YwIakFLdruv2AoaArnQ8P8HAQ
